jordache16
- Joined
- Jul 21, 2012
- 19
I have an 82' Century Sport 2000 with a Mercruiser 305 that is running rough under load after warming up. Engine runs great for the first 30+ mins at both low speeds and high speeds. However, after it gets warmed up, the engine starts to sputter and loses power. It usually won't die after it sputters like this rather it will return to idle and run just fine at idle. Then if I go to take off again, it will sputter and not want to go. I have found that the issue goes away and/or does not crop up at all if I take the rear engine covers off and let it run like this in the open air. This makes me think the engine is getting a little too warm, however the temp gauge never goes above 165 and sits right at 160 most of the time. The exhaust manifolds do seem fairly warm/hot if I touch them after it gets warmed up. Is this normal, or should the manifolds be cooler? Also, is there a way to test if the water is circulating through the manifolds and risers appropriately?
As a quick fix, I already tried changing out the ignition coil thinking it may be going bad / not delivering enough spark when warmed up, however that did not fix the issue (ignition coil being a 1.5 ohm Pertronix Flame Thrower). I haven't ruled out spark/electric side of things. I am wondering if the alternator should be replaced as it is the original alternator and only charges around 13.1V according to the cluster gauge.
Any other ideas of what it might be and/or how to diagnose the issue? I think the key is that it runs great / no issues with the engine covers off. With engine covers on, it will run fine at idle / putting speeds but when you give it throttle and put it under load it will start to sputter and want to die after it is good and warmed up.
