Donald0039
- Joined
- Jun 11, 2022
- 418
Look for a 5 part video that discusses in great detail rebuilding a VP 290 drive. The guy that did the videos has "cave" in the name.
No, it's there to keep excess grease out or bilge and help keep dust out, can be reusedOk, I've picked up a new complete outdrive, going to replace the gimbal bearing, thinking I should do the seal behind the bearing?
Most all the new gimbal bearings are sealed and no longer greased. Check to make sure your bearing has a hole in the race so it can be greasedAlso, can't find 18-9200-4 Sierra grease anywhere even on amazon, is there an equivalent that would work as well?
Not sure what that is, so can't say.You sure the lines are not SAE inverted flare?
its is a 7/16"
For better access that can reach around the solid lines, check these out link
they worked great for me to replace my lines without pulling anything of
Torque loosen, torque ... 3 times.
