sandsmccoy
Thread starter- Joined
- Oct 28, 2010
- 1
Greetings - My apologies for the long post but I want to be certain if you take the time to read it you understand my situation. I have a 2008 2500 SS Ebbtide deckboat with a 5.7 Mercruiser and alpha one outdrive. I've been fighting a starter issue ever since I purchased the boat 5 years ago where the starter will not properly engage the flywheel (it will begin to spin the engine and then pop out) when cold especially after it has set for a few weeks or at the beginning of the boating season. Once you have gotten the boat started and as long as you use it regularly (every couple of days) the engine starts without any issues. I have replaced the starter 4 times and even replaced the engine (new crate engine from Mercruiser). The engine replacement was a last ditch effort to cure this problem and was performed by a qualified Mercruiser mechanic at our local marina. It worked fine for the break-in period (30 hours) and then toward the end of the season started behaving like the original engine (which had roughly 1600 hours). I have replaced starters on GM 350 engines in more cars than I care to count over the last 50 years and have never encountered anything like this. Yes, some of the car starters needed to be shimmed (the older ones especially) but according to all the "experts" you do NOT shim this starter on a mercruiser (however, I have tried and it made no difference). I'm at my wits end and am ready to dump the boat even though its a great performing boat once you get it started. Has anyone else had a similar problem on an engine of this era. Any comments, advice and/or suggestions would be much appreciated. Thanks in advance.
