2008 Chaparral 275 SSI 8.1 Volvo Penta GXI-J Soft Alarm Issues
apisk
The connection to the new sensor
Does the voltage change when TPS is moved from idle to WOT?
It goes from 4.10 at idle to 4.11 at WOT (I didn't test this with the engine running, just with the sensor plugged in and moving it by hand)
tpenfield
I am thinking . . . What is the difference between
TPS ( Thottle Position Sensor)
and
TCP (Throttle Control Position) ???
I'm thinking the TCP is drive by wire, where there is no throttle cable. There must be something else in the overall circuitry that is shorted out and the TCP sensor just completes the circuit.
tpenfield
I'll go back and look at the data to see if anything else comes to mind.
tpenfield
It looks like TCP only activates when the throttle control is put in gear.
tpenfield
Also, a 14% TPS at idle speed seems way too high. It should be more like 0-5% .
Perhaps the issue is the TPS and not the TCP. :unsure:
Sorry for the multiple messages . . . I am multi-tasking with this thread and my Evinrude 25 HP, which I've been working on much of the day. 🤪
apisk
I just ran the graphs in Diacom from the recording I sent, and if you put Knock Retard with Soft Warning Output, the Knock Retard jumps exactly at the moments the soft alarms go off, and then go away at the same times too. So far that is the only combo that has been aligned
tpenfield
Here is another combo . . .
When the TPC are over 50% and the difference between the TCP and the TPS values are 15% or more, the soft warning occurs.
2 examples . . .
I am wondering if the TCP and TPS values should be close if not nearly identical, and when they are not and at a certain amount of control position, it sounds the warning.
tpenfield
What happens to the reference voltage if you remove the TPS ? Not sure you did that . . .
apisk
apisk
2 examples . . .
Running with this theory, the only way to truly test the new sensor is by running the boat (and not just testing the throttle when off like I did) correct? That way we can see if the TCP % are more aligned to TPS with the new sensor?
tpenfield
I was thinking the TPS may be the issue, it starts of higher than it should and ends up lower than it should
apisk
Do you know if the TPS is on the throttle body? There is a thick plug but not a clear sensor like the other 8 (circled in red)
tpenfield
Not sure. You should use a parts diagram to locate it. I'm reaching the extent of my V-P knowledge, sorry to say (I'm more of a Mercruiser guy, and they use a different approach to the throttle control) . . .
Maybe the member @muc might be able to offer some suggestions.
tpenfield
Another thought that I had was. . . . something going wrong in the throttle control itself. Is there a full wiring diagram for the engine? The one you posted was for the controller itself and somewhat generic.
Also, keep in mind that this effort (so far) is only to get the 2 voltage sources to be at their 5.0 volt spec. Then it is a matter of seeing if the alarm and knock sensor issues are still present.
