rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Been messing with this awhile....
Have main 100 gall tank that was reworked 4 yrs ago. Works great.
I have 2 side Aux tanks 22gal each port/starboard. 1 main tank line pairs with 1 the port for port motor, visa-versa for Stbd tank. I Can run small tanks, big tank or all paths open together.
I pulled Aux tanks this spring, the have new bungs welded, cleaned, new pickups etc. I did my own rinsing (so i thought)
1st time out had idle and stall issues, I thought on 1 motor only due to 1 Aux tank..inspection showed a fair amount if water in seperator. I drained carbs, tank, repl seperator etc....now i seem to have similar on other motor.
However, now keeping the Aux tanks shutoff, running on my proven Main tank...each motor very intermittant will try to die if idling.
I still feel its water, is there another place im missing to drain? Ive tested samples ea h tank-looks ok now...seperators have been done twice.
Once seperators get saturated, do they still flow? Or just bypass water into the fuel path.
I fished 10 yrs like this, more annoying than anything, but want to solve it. Always ran like a top, I do all my own maint
