1969LarsonRude
Thread starter- Joined
- Jul 9, 2022
- 20
Here's my summer puzzler. Working on a 1969 Evinrude 85 hp model 85993E. Can't get it to run.
I have strong spark on all plugs. Battery is fully charged and it turns strong. Fuel is good and making it to the cylinders. Compression is good. Flywheel key is not broken. I set and cleaned the points when I replaced the amplifier, coil, and anti-reverse spring last fall. I replaced the fuel line and primer bulb last year as well. It started fine after I did all that. I winterized the motor, filled the tank with rec fuel and added StaBil for good measure. Stored it it indoors all winter. It ran in May after I got it out of storage
Not firing now. Like not at all. A few days ago it ran for 5 to 10 seconds. (Got a backfire out of it too, but I don't remember which happened first.) Regardless, I get nothing now - even with starter fluid.
I'm stumped. Couple engine buddies who have looked at it are stumped. What should I be looking at next?
Pics at the following link if they're useful. (Make sure you're sorted by date and looking at the most recent)
