nola mike
- Joined
- Apr 22, 2009
- 5,956
Been talking about installing an A/F gauge since putting in the Edelbrock 1409. Since the boat is (for now...) running well, I did "fun" stuff a couple of days ago (shift cable repair wasn't fun I guess). Cleaned the boat for the first time since it was dunked more than a year ago. Polished, waxed, cleaned/oiled teak, vacuumed out all the residual sand, etc.
Got A/F gauge/wideband O2 kit and Hardin spacer to fit between elbow and manifold. @Scott06 did this previously and gave me some tips. Figured I'd document the install and tuning. Fairly straight forward with a couple of caveats.
Was able to separate the elbow from the manifold without completely removing it, the shift plate, or hoses. I did remove the canon plug. Gasket was pretty intact and only stuck to the manifold side, so wasn't too bad to scrape off.
Hardin calls for using 2 open gaskets. I have the partial restrictors on there, and decided to keep it that way. Only issue was that the bypass holes didn't line up with the passages on the spacer. I drilled a hole in each gasket to line up with the spacer holes. Don't know how necessary this was or what the purpose of the holes are (just to bleed air I'm guessing). Spacer with holes on top, gaskets with drilled holes (2nd holes from left) beneath:
Second big tip from scott was that the pipe plug on the manifold interferes with the O2 sensor. You wouldn't notice this until you put everything together. I ground the plug down with the elbow out of the way. This would be extremely difficult with it installed.
Other thing is that you need new bolts 1" longer to account for the spacer. 3/8-16 x 6.75". Turns out that these are difficult to find locally. 8" are available, but partially threaded. Cutting them down and you'd lose your threads. Not proud of it, but temporary solution is to use 18(!) washers on each bolt. Trying to find some 7" grade 8 bolts, but the usual online sources have them end up at $30 or so for 4, which hurts. I don't know that I need grade 8 for this application, I did find some 7" grade 5s that I might use.
Lastly, what should have been some straight forward wiring of the gauge into the ridiculous daisy-chained rat's nest of wiring at the helm. I should install a couple of proper busses. But didn't. Can anyone guess the useless gauge that I replaced?
