- Joined
- Jul 23, 2011
- 53,304
I suspect the tank is full of water and crud, so the anti siphon valve is plugged, the carb is plugged
Post 14I cant reference any of these numbers on line for a rebuild kit. Can anyone identify the carb and kit number? Holly on the float bowl Its a two barrel
thanks
randy
forums.iboats.com
Ayuh,..... For the accl pump, where ever the motor doesn't bog or stumble when you drop the hammer,.....update I had the carb rebuilt and it idles nice and seems to rev good. Runs rough at 1.5 turns up from seated on both sides but 1 turn out seems good. Does anyone know what the accel pump adjusment should be? Also i have a vacume line coming up from the fuel pump and i cant remember where it goes. Holly 2 bbl.
randy
