CATALINAWineMixer
Thread starter- Joined
- Jul 12, 2023
- 29
Hello,
I am hoping you experts out there can help guide me in a repair/restore I have found myself in the middle of..
I bought a boat 2 years ago and got some great use out of it so far but when inspecting at the start of the season, I noticed the a previous patch job was looking extra bad this season. I sought out some advise prior to doing any grinding from a local boat restoration business who gave me some pointers as he could tell that I was determined to fix it up but couldn’t afford his services when I only paid $1800 for the boat itself and the repair was going to be between 5-10,000 dollars (rough estimate). I had pictures that I showed to him of the old patch job prior to doing any grinding away. I let him know I was hoping to do a one sided repair and he said the only chance I would have at that would be with epoxy.. I pulled the trigger on a 5-gallon epoxy/hardener kit and some supplies from US Composites that ended up being just over $600. I initially thought I wanted enough for the hull and the deck so I figured the 5 gallons would be sufficient. After spending 3 days removing material, I realized I would probably need to rebuild the stringers as well, something I had not factored in to my repairs.. the work I am doing is while the boat is still trailered to add to the complexity..
How far will the 6.25 gallons of epoxy/hardener get me? Am I better off at this point trying to arrange a return to USC and eat up the 10% restocking fee and shipping, then purchasing laminating polyester resin instead? I do not know if the transom is affected yet, but I will say for a 40+ year old boat, the thing still feels solid!
The floor felt solid minus the front section around the storage compartment with close up pictures included to this post. I planned on replacing the front section of the floor to past the front seats mounted in the floor for captain and passenger. At this point I feel like I’ll have to do the entire thing since the gas tank is underneath the deck and in one of the pictures of the hole I been grinding I could see one the stringers toward the stern were “floating” the glass tabbing from the bottom of the hull to the stringer has delaminated completely. (Yikes…)
Any advice would be greatly appreciated as the 30-day return window is going to close fast.
I have attached as many pictures as I can!
Please send the heavy hitter advice! 🥹
