theplumberdan
Thread starter- Joined
- Jul 13, 2023
- 5
Gents My boat runs rich and dies going neutral to forward or reverse, runs like it does not have 315hp. All eight cylinders have 175lb compression w 580hrs on engine. I had the boat scoped and a bad ignition module code was found. $550.00 later, new module, same day I got boat back I took it out same problem yet it does idle a bit better. I have gone thru 3 fuel pumps in 2 yrs. At idle I get 20lbs. Tank appears to be clean. Should I go after Market pump and regulator to get 50lbs? Any ideas? Thank you...
