Lou C
- Joined
- Nov 10, 2002
- 14,154
Thanks to All Dodge for info on how these newer systems work and glad you’re getting better results. Hope the water test goes well.
BTW the deposits you see in an engine that’s been run in the salt are actually calcium more so than salt which dissolves easily in water. This is what I saw in my old cyl heads when I replaced them in 2017. While you could see calcium deposits it wasn’t much & not enough to restrict the cooling passages.
Running the deposit removing solutions is probably a good idea with raw water cooled engines in salt. Even so I haven’t done this & any overheating issues I’ve had were due to other causes….marine growth in the lower unit, clogging in the manifolds, etc. Even with the old original block from 1988 it runs at a cool 160* except when coming off plane when it may rise to about 170-175 briefly.
My brother’s boat (2020 Chaparral) with the 4.5 200 hp runs at a cool 140 all the time…
