tango13
Thread starter- Joined
- Mar 10, 2015
- 88
1995 7.4, carbed. New block and bottom ends, 30ish hrs. Last season I battled hard start/no start when hot. Engine would crank but not fire after warming up. The boat was new to me, so I hadn’t figured it all out yet, but my old boat with a 350 would start with a bump of the key every time.
I never did figure out if it was spark or fuel, so started with a few items before the season started. My batteries were shot so I did two new 1000 crankers. Replaced ignition sensor (took apart old one and it was caked in rust), cleaned flame arrestor, and did new plug wires (coil wire was corroded so bad in coil that I had to pull out with pliers). Cap and rotor were good. Pulled a few plugs and appeared to be good. Also wrapped the fuel lines in header wrap, plus rubber hose as I struggled with ruling out Vapor lock, which I believe is not the case as I have cool lines and have been running ethanol free fuel.
Took it out and it ran WAY better, but it gave me that never ending crank/hard start after running all day. Brought a spark tester with me and confirmed I had spark. Got it to catch after just cranking it for 10-15 seconds. Awesome. I’ve been playing around and doing lots of reading, and tried the whole WOT when starting. It did work and I get a big puff of black smoke once it got going, though I was pumping the crap out of it at first and obviously I flooded it from that. Also just tried cranking on it with no throttle and after about 8-10 seconds it starts to catch and go. Been doing the latter procedure for the last couple weeks and it’s been consistent. I pulled the flame arrestor one day to watch the choke (which I think works fine) and noticed the carb was dribbling fuel from the Venturi while idling. Not sure if that’s normal but from what I’ve read they shouldn’t do that (it’s a carter/Weber 4 barrel). It didn’t dribble at shutdown but I didn’t wait around long enough to watch. My symptoms almost seem like it’s running a tad rich and then flooding at shutdown. When it’s cold, it fires right up so I know my fuel bowls aren’t evaporating/dry. Does this make sense?
Next step I’m thinking is a carb rebuild, I wonder about the needle not seating as maybe something got in while it sat on a bench during the motor job. Also contemplating a fuel pump but I’m not getting any other symptoms and I haven’t confirmed pressure. Boat runs awesome when it’s running, absolutely perfect. One thing I have noticed is that the boat gets super smelly with exhaust when it’s idling (thru prop exhaust) but it never seems to load up as if it was flooding bad that could just be me not being used to a big block?
