Steering issues on a SeaStar steering
Status
Not open for further replies.
PClarence
My 176 Key West is equipped with a SeaStar steering pump and a BayStar actuator at the motor. When driving the boat, it won’t hold a coarse. It constantly veers to port (left) and requires constant turning of the steering wheel to keep on coarse. I bled the actuator. No change. Replaced the steering pump. No change. It’s holding the fluid level. No leaks that I can find. Any suggestions?
04fxdwgi25
Doubt it's the steering system. Maybe a bent skeg on the lower end of the motor? Something dragging in the water, like a transducer or a trim tab? Is the outboard mounted square on the transom?
jimmbo
Even the Trim Angle of the Engine/Outdrive will affect the Steering. With Right Hand Rotation Props, a Pull to Port usually means Trimmed to far out
PClarence
Why I still go back to the hydraulic steering is when the boat is not in the water and you turn the steering wheel as far to the port or starboard as it can go , you can still turn it . All be it with some resistance, there is no “stop “ . In addition, before this happened with the boat out of the water you could physically move the motor by pushing it and the steering wheel would turn. That doesn’t happen now. The boat is ten years old. No trim tabs. Transducer has always been there. Skeg hasn’t moved and is straight unchanged. My thoughts are that hydraulic fluid is leaking past something internally.
dingbat
The helm is simply a pump. It's possible you blew a seal(s) in the cylinder, but not lkely
How old is the steering system?
PClarence
The boat steering is 10 years old. If left with no clear solution, I would replace the seals next. I would have thought if the seals were blown there would have been leaks on the outside. There is no external leaks.
Chuck4741444
Just proves your rod ends are not leaking.
Double ended cylinder with supply and return on opposing ends. Piston and seals sit mid shaft.
I know this is and old post, I put excessive pressure on the sea star hydraulic cylinder. I belive I blew the internal seal, I can turn the wheel non stop either direction, and can push the motor side to side. There is no resistance.
I have no leaks. She is full of fluids
It almost like the fluid is circulating through the cylinder,
Can I buy the parts to replace the internal seals? Not the seals on the ends of the rods...
Status
