Black Scorpion Mag Mpi fuel pressure
Dremmick1985
According the 24 service manual I am supposed to be getting 34-38 psi. Is that at idle with regulator vacuum connected? I'm getting 26psi at idle with regulator vacuum hooked up. If i disconnect the vacuum should it increase? I'm to determine if I have a fuel or regulator issue. After a few minutes of >3,000rpm rpm's will drop to 1,000rpm out of no where and try to recover.
Fun Times
At idle is fine for testing too while some service manual recommends checking the psi at 1800 rpm under load too <in which is the better thing to do depending on issue type.
When all is working normal the fuel pressure should go up to the regulator specification when you remove the vacuum line at idle and then drop back down when reconnected.
See the document on the left side of the following post number 7,
What is your engine serial number and engine/boat year if original?
Agree, need a serial number, the Black Scorpion had several changes but only ones that list 43 psi is 17 and 31
Manual 17 from 1993 to 1997 Scorpion 43 psi
Manual 24 All 30 psi
Manual 31 for 2001 and up All 43 psi
Dremmick1985
2004 scorpion mag mpi SN 0M393328. Is the regulator spec the 34-38 or 30psi what is show on a bracket over the regulator?
Fun Times
Lets go back, What is/does the PSI do when you remove the vacuum line at idle? You're at 26 right now so it ought to jump up to 30ish psi spec when you remove the line...Need to recheck that test.
Next this is where you'd need to be in the water with the fuel tester gauge connected to see if the fuel psi is dropping when the engine drops RPM.
Bear in mind that your engine system seems to have a low fuel pressure booster pump inline as well,
Dremmick1985
26 psi with vacuum attached and 32 with vacuum line disconnected
Fun Times
You're in spec for now... If possible, go run the boat with the fuel gauge connected ... Also suggest bringing an external fuel tank and fuel hose to bypass the boat tank and see if it runs normal...Also open the boat fuel filler cap to vent the boat tank to see if it helps any...50/50% chance there.
Let us know, good luck.
Dremmick1985
Its a fuel related issue, my pressure would slowly creep down after a couple minutes and started to run lean around 15psi. Opening the gas cap did not help. I ran off the an auxiliary tank plumbed into the low pressure fuel pump and did not give me an issues until I ran out of fuel. It was only a one gallon fuel can. At 2500rpm im still only at 27psi which is lower than the 34-38psi spec. I need to inpsect fuel pickup in tank and anti siphon valve.
Antisiphon valve
It's the barbed fitting the gas line is attached to
QBhoy
Have you checked the engine oil for signs of lots of fuel in there ? Just in case you have a leaking injector somewhere ? Could test the injectors perhaps ? Sorry if that’s been covered already.
Other thing you could do…is using the shrader valve on the rail…key on and off the key to get the pump running…check there is no sustained signs of air from the rail. This could mean that you are drawing air from the LP side of the pump. By means of the filter or a compromised fuel line perhaps. The pressure can only drop (in test situations) by means of air induction or a leaking injector, most commonly perhaps. Often just the sound of the fuel pump can tell a story.
You’ll also maybe already know…but on some of these type engines, of a certain era..there was known issues with the internal coating or paintwork finish within the fuel pump and regulator components. Caused flakes of it to block or restrict the lines. Usually meant a lean popping condition when running up the rpms.
Dremmick1985
No fuel in oil or leaks. I should remove the hp pump and regulator to take a look.
QBhoy
Yeah. Good idea maybe. Can’t remember quite the exact details about that. But look up mercruiser mpi fuel pump paint or something similar
QBhoy
Found one of the reports on here. Loads online. Is it the cool fuel you have ?
Can this be tested? Or do I just replace it?
Kind of, you should be able to blow thru it with very little pressure from your mouth, don't blow hard. You should not be able to blow thru it with more pressure going back toward the tank
Dremmick1985
Well I found the culprit. Suprised it even ran. Hard chunk of of something plastic/glue and varnish
