Oillywater
Thread starter- Joined
- Jun 10, 2023
- 96
Hello I have a 1988 force 125 bay liner capri
My problem is that when I have the boat out the water and I start it. It starts right up and will stay in it will stall out occasionally but for the majority of it it runs good and stays on. Took it out to the water and it has difficulties starting and when it starts it idles but stalls the if u put it in gear you have to dump it in gear or it stalls.
Before I was on here since it wouldn’t start. I had a magneto problem but I just disconnected it on the motor and have been killing it with the choke. Then it was timed way off set the timing and it ran good. Now I just have this problem. I’ve cleaned every inch of the carbs multiple times only thing I notice is the bottom carb idle screw is very worn out. I’ve changed the fuel pump gaskets and port cover gaskets.
Please help me. And maybe I can use this information for my jetskies as they also are the same but they just won’t start in the water but out they instantly start
