guy48065
Thread starter- Joined
- Aug 31, 2008
- 575
This '71 9.5 I'm working on has been slowing down & stopping after a couple minutes running in a barrel. Everything checks out on this motor but I haven't got into the carb yet. It runs so well when first started I was hoping I didn't need to rebuild the carb.
Somewhere in the service manual is a fuel pressure test that says to not place the gas tank more than 30" below the inlet when running the pressure test...so...I put the tank on a waste basket and then the motor ran on & on (but with some rpm variation & the occasional cough...I might need to dig into that carb anyways).
My question is this: *should the fuel pump draw fuel from a foot below the skeg*? It seems to me that it should--even though in normal use this would never happen.
The SM really doesn't explain this.
