BB63QM
Thread starter- Joined
- Aug 4, 2023
- 79
I'm new, so bear with me. 1973 Thunderbolt 850; just purchased and rebuilt carbs and in boat electrical. She starts, but only on ether (suspect is weak spark due to old plug wires---solid copper replacements on order), but the prop does not seem to free up in Neutral as i would expect...its not engaged, but its not free either (as if the dogcam is disengaged, but not centering out, so its banging on the gears. Reverse Locking Cam: The prop rackets in forward as I understand is normal; in Neutral it moves in both directions but with an click click click every half rotation that you can hear and feel (like a bike derailer that is out of adjustment, but scaled up). If I move the shifter further back, the propeller frees up completely, when i expect that it is supposed to be fully locked to the drive shaft in both directions.
I read somewhere that the locking cam sometimes takes a little to engage, but no matter what I do (hand spin fast in either direction; raise, lower the motor in forward and in neutral, reverse spins free as opposed to being locked in both directions.
Please tell me that this is a stupid question, that there is an easy fix, and that I do not need to drop my L/U or replace anything major....I'm running on fumes after fixing all the problems I already found. fingers-crossed.
Thanks in advance.
Thanks in advance.
