Trouble with hull ID number
bobdole31
I recently purchased a StarCraft boat from a young man who knew nothing about it. After some research I believe I have a 1975 Mariner O.B. That’s where everything gets weird. The boat was registered in Minnesota as a 1974 with a hull ID 992591. I have learned that every boat starting in 1972 is required to have a 12 digit HIN. I found the tag on the upper right transom and it only leads to more questions. It’s a 14 digit number that I have tried to enter into the HIN decoder https://www.marinetitle.com/library/hull-identification-number.aspx in every combination I can think of with no luck. Any assistance will be very appreciated. I’m trying to title it in Florida and I have hit a brick wall.
roscoe
So it only works if I pay $20?
If you use that website, yes.
They are charging you for info that is available for free.
Try the site that jb had posted.
Www.hindecoder.com
boat was built in December of 1974, probably originally sold as a 1975 model, which was common.
Where did you get this from???
""with a hull ID 992591"" ?
bobdole31
Www.hindecoder.com
The Minnesota registration.
jbcurt00
The # on your registration is the Ser# that was inadvertently used as a HIN.
Probably occurred when sold and registered possibly from a no title state to a title state. Happens all the time w old boats
If the current registration is valid, I would leave it alone, and not attempt to correct paperwork as long as that Ser# and plate are legible
bobdole31
I’m trying to register it in Florida so that’s why I’m going through all of this. Thanks for the help with the hull number.
jbcurt00
If Florida accepts the shorter Ser# as a HIN, since it's on old registration, let them
bobdole31
That’s what started this whole thing. They wouldn’t accept the incorrect number and they said the number from the boat showed invalid in their system. I even had them try it without the 75 on the end. The county said they couldn’t register it with a discrepancy and I had to talk to the state of Florida DMV to fix it. The DMV said I had to get Minnesota to fix the discrepancy and so I’m trying to figure out how to do that since I’m obviously too far away to do it in person. DNR said today they may be able to change the number in their system if I request a copy of the registration and send a picture of the HIN with the form.
jbcurt00
Tried registering it in your name in Wisconsin via online?
DLNorth
You have an interesting story.
I'm wondering if somebody has done some work on that boat and mixed up tags and paper work.
Being from MN, I know from personal experience the DNR can be somewhat "loose" with boat reg's.
If it were me, I'd go the route of transferring it to "me" in MN and have them (MN DNR) change the S/N to what is on the rear plate. (If a PO hasn't changed the plate it has the highest probability of being correct.) Once you have it reg in your name in MN, then transfer it to Florida.
Also, that S/N on the papers S/N 992591 is a number from 1971, and the rating plate you show, that style was used in 1974 and newer, with the stamping in the top space, I'd guess early '74.
1975oday22
UsedHINSTR19404M74L
IsValidYes
IsValidMICYes
HINTypeModelYear
SerialNo19404
Year1974
IsStateIssuedNo
CompanyStarcraft
CompanyStatusIn Business
CompanyAddressNew Paris In Po Box 65
Website
