Raystownboater
- Joined
- May 16, 2010
- 510
Mercruiser 165, with no spark at the plugs. The wiring at the coil didn't look correct because the wire from the condenser was hooked up to the + of the coil and there were groups of wires just randomly hooked up to the coil. I looked at the wiring diagram which showed the condenser wire connected to the - side, along with the wires to the shift interrupt switch. I wired it like the diagram showed, added a jumper wire to the + side, to make sure it had 12v. Verified the points were sparking, put everything back together, and cranked it over. NO spark anywhere, and the points started smoking and melted. What in the world am I doing wrong?
