2004 Chaparral Sunesta 216 engine not starting 5.0 L
CowboyKenny
Good morning, I am looking for some assistance to try to figure out why my engine won't start.
Recently I replaced spark plugs, wires, distributor cap, fuel water separator. Engine will turn over but will not start, from what I can tell it doesn't seem to be getting fuel. I am going to check pressure once my gauge arrives. Any ideas or suggestions? Thanks in advance. have a great rest of your day.
Ayuh,..... Welcome Aboard,...... Carbed,..?? Efi,..?? Mpi,..??
Try prefilling the fuel filter,.....
Good morning, sorry I could have added that. It's EFI.
Ayuh,..... So try prefillin' the fuel filter, 'bout as full as you can, 'n still reinstall it, without dumpin' gas into the bilge,....
^^Agree
If that doesn't work, and don't know if it's a MPI or TBI but if you have a schrader valve to test fuel pressure, press in on it to let air out
Scott06
As mentioned above likely not getting fuel due to filter change.
Would also verify you are getting spark. since you changed cap wouldn't be the first time a new part was defective or wire from coil got left off
QBhoy
Battery being the issue, is odds on for me, at the moment.
