Boatbuyingloser
Thread starter- Joined
- Feb 9, 2021
- 37
I have a 1993 Maxum 2300 SCR with a Jasper rebuild 5.7
I recently had a lot of work done to it, bellows, plugs, plug wires, distributor cap + rotor, compression checked, and a brand new carb but I’m still having issues getting on plane. It’s a little hard to start, and once started the RPMs seem to be low for the first 10 seconds or so, then come up to regular idle. I say “seem to” because my tachometer is usually off by +1,000 RPMs but will sometimes correct itself (could be part of my issue)
This was an issue before the work was done and continues to rear it’s ugly head most days I bring the boat out.
The boat usually runs fine (maybe a little rough, hard to tell as I’m used to it now) and can rev all the way to the top just fine in neutral (accidentally did this one day when it was particularly hard to start) however once I try bringing it on plane, it feels sluggish and at about 4k RPMs it will drop down to about 2,000 rpms before trying to jump back up. (Surging?) I’ve had to limp back to the boat dock at just above idle the last couple weekends.
Before spending more money at a shop, I’d just like to hear some input on what you guys think could be the culprit.
