IanFS
- Joined
- Apr 21, 2009
- 188
Alpha One 1988 attached to Mercruiser V6 1988
Hi guys,
I haven't been able to use the boat this year, weather's been sh*te and people visiting etc. However with a break in the weather, no company and Mrs FS working I bought the boat home from the yard to do some checks etc.
Engine runs fine but after the first run up adjusting the throttle cable etc, I noticed a dribble of oil at the end of the prop and wiped it off. Next run up a small drop or two of emulsified oil at the end of the prop. I took the prop off suspecting a weep from the prop shaft oil seal but nothing, plus nothing in the lower housing.
I replaced the upper seals a few years ago. Drained the oil to check for water emulsion but its clean. Took off the lower housing to check the usual suspects, water pump seal onto drive shaft, also to see if there were any signs of a dribble on the drive shaft. The shaft was covered in soot but no sign of an oil dribble and no signs down the exhaust either. I took off the water pump, but couldn't see any signs of oil leaking from the lower gearcase.
New water pump on order but I'm stumped now.
Any suggestions will be gratefully received.
Hi guys,
