jimmbo
- Joined
- May 24, 2004
- 14,664
Since no one on this Board, can actually see or touch your Outboard, any and all suggestions are based on the Info you provide. If the info is incomplete, or more Info is added, a new reply, seemly in contradiction to earlier replies, may appear.
An engine needs 3 things, in the proper amount, and at the proper time to run:
Compression, on a 2 stroke, both Crankcase and Cylinder.
Fuel
Spark.
Take away any of the above and it doesn't work, or work well
The carbs might be adjustable for elevation, but no info is shown as to what parts maybe required. Your carbs are fixed Jets for both Hi and Low speed, not my favorite choice, but it does prevent users/mechanics from setting things too Lean on one or more carbs
Fuel
Spark.
