Brett LaRue
Thread starter- Joined
- Aug 6, 2023
- 12
Replaced the gimble bearing (its seated properly) and u-joint assemble along with everything attached to the bell housing. All new seals and O rings. The Sterndrive won't go on all the way about an inch out.
I didn't over grease the end of the saft.
The shift leavers are mating properly in forward.
The plastic end to the shift cable is inside the sterndrive.
I used my alignment tool and it slides in to the last notch on the tool and I can turn with two fingers. But when I take out I don't see the traces of splines in the grease. See pics
If it is indeed aligned could it he the O rings on the shaft? If so, would some moderate hits with a rubber mallet be ok. Any other advice welcome. This project is killing me.
