carterme1968
Thread starter- Joined
- Jul 31, 2023
- 5
i have a 2010 tahoe Q5i with a 4.3 MPI 262 CID V6 fuel injection..First issue I had was engine idling but when giving throttle boat wouldn't go. Took it to shop and they replaced spark plugs. Now boat will idle good and run good in water but if I stop it then like 10 minutes later try to crank it, it will idle rough around 500 rpm's then a few seconds later cuts off. If I give it gas before it cuts off it will just cut off sooner..Then waiting in water for 5 to 15minutes(trying to crank several times during this time which it cranks, idles then cuts off) it will idle fine and I'm good until I cut it off again. This doesn't happen each time. Normally if I cut off for more than 5 minutes it happens more times than not. Like to get some ideas before taking back to shop. Thanks.
