Cali_Boat_Guy
- Joined
- Jun 7, 2022
- 82
I have an '86 Sea Ray 270. The hole for the Garboard drain is about 1 1/4" in diameter. The garboard drain on the boat now has a sleeve, the part that goes into the hole, about 1 1/8" wide. The problem is the sleeve is too short to cover the exposed transom wood in the hole. If too much water gets into the bilge then the exposed wood will get wet. Where can I find a garboard drain that is a little wider in diameter and longer to cover the wood? Should I just use 4200 sealant to cover the wood? As always, thank you for your help!
