goodmariner85
Thread starter- Joined
- Jun 19, 2023
- 53
The kits were 28 dollars on amazon. Supposedly Johnson Evinrude, and that's what was written on the bags. And maybe BRP. Unfortunately, I tossed the bags. The old floats had the OMC M molded in. The new floats just have a number molded in. I did keep both old floats and gaskets and one pin and seat.
I tried removing the float, inserting the pin and dripping carb cleaner in the seat. I did not see any leak back into the input port. Not a very precise test though. Lifting the pin a bit does let it leak through.
Regarding warping, that's a good point. I just now put them on a flat granite surface and applied moderate pressure on two screw holes. The biggest gap I found with a feeler gauge was 0.019 inch on one and 0.020 inch on the other. That's with no gasket. I have a lower-range torque wrench that I have not used yet. I'll have to find a phillips attachment.
