chs marine service
Thread starter- Joined
- Jun 29, 2019
- 89
so i got this boat with a 2004 merc MPI, 4.3 engine. the customer overheated due to picking up a plastic bag and starving the impeller of water. i pulled the heads after finding low compresssion and had the checked for cracks and resurfacing. changedthe oil, etc... reassembled the engine and she ran great temp @ 150 for over 20 minutes,. i shut it down to finish cleanign the engine compartment and as i was about to sign off on a job well done, i checked the oil level and fouind i had over 2 gallons of wate/oil mix. i drained the system , flushed it out with diesel fuel, replaced the oil & filter.
started up, again, ran great but went into overheat, oil level stil ok,. i emptied the coolant system by means of the distribution bottle and started the engine to watch the flow of water getting to the engine. which was fine, i closed the valve and she ran @ operating temp again for over 20 minutes. thats as far as i went.
ive been racking my brain and i know i did not miss anything. the engine did not cook itself so bad that it melted the shutters and the bellows (exhaust elbow tubes) were fine so i have pretty much ruled out a cracked block but what else could i be looking for?
this is a dry joint manifold system and they were replaced when i had the heads off. when i had the heads off i did find that the water hose comign from the distribution manifold to the port side manifold was clogged with dirt/ silt for about 18" so i replaced that and checked the starboard side but it was clear. i stuck a pick into the engine block and did it was open.
