- Joined
- Jul 23, 2011
- 52,346
good advice here.I would have put a Roller Cam/Lifters in,
Would that work with the non adjustable rockers?good advice here.
should, however you would have to look into the proper push-rod length.Would that work with the non adjustable rockers?
not with the conversion kit.The stuff I read online made it sound like converting to roller cam required block modifications.
er gaskets and it looks like part of rubber squeezed half way out. We'll see if it leaks when I try to start this thing tomorrow.Haha yeah a bit of mood lighting with mixed deck and engine room llighs.That blue/purple lighting looks really cool. I assume that you will be running with the engine hatch open just for visual effect.
Not sure if it was covered during this thread, but I assume the engine is a gen 5 454The gen 6 had the roller lifters and may have avoided the issue.
My main concern about the in-boat repair is/was the ability to get any/all metal shavings from the cam shaft/lifter out of the engine. Hopefully you've got that covered.
Yes, lifters came with new camshaft. Coated them in Driven Assembly lube.May have missed it but I guess you changed all the lifters.
