Copper crush washers ok to use?
Rob406
I just changed the lower unit oil on my (new to me) 96 evinrude 50 spl. I bought evinrude plastic crush washers, which did fit the drain plug. But the vent plug was different and all i had on hand was my copper crush washer set. Talk is cheap so i thought i’d ask the board. By the way the vent plug put up a good fight to break free and i replaced with a 1/4-20 stainless phillips pan head bolt. Found an allen head as well, but i felt it didnt have enough of a shoulder. Thoughts?
Copper and aluminum do not like each other from a galvanic corrosion point of view
tphoyt
If your in salt water copper and aluminum don’t go well together at all and the electrolysis will eat your lower unit in short time
Rob406
Thanks, i wasnt aware of that. Is plastic the best option then? Hopefully I can find something at the hardware store. They have the white poly washers but not sure if they are intended as a crush washer
Even in fresh water galvanic corrosion will be an issue
Use the plastic crush washers
Rob406
Okay will do. Since it’s just the vent plug, can i just pop it off, replace washer and reinstall?
Also does it have to be a specific crush washer? Ace hardware has the plastic washers that look exactly the same as the evinrude washers, but they are not sold as a crush washer. Not really sure what they are for.
The plastic washers at Ace are nylon. Nylon is hygroscopic (absorbs water)
Not sure the johnyrude crush washers are nylon (I don't know what they are made of)
Rob406
Jeez glad i asked. Well i hope evinrude knows that. Ok so my options are the fiber drain plug washers at ace (which i assume would be a no go) or i could try napa to see if they have a 1/4” plastic crush washer (usually blue in color with ribs on it if i remember correctly. They also have some hard black ones) Really trying to get on the water saturday and work 8-8 tomorrow unfortunately. Thoughts on the washers?
Depends on the fiber base. Paper or fiberglass?
The black ones may be acetal (delrin). Those would work if they are acetal
Rob406
Thanks. The factory vent plug was a special screw and was slotted for an o ring. So not sure if i will be able to find a washer. Hoping maybe the dealer has a new screw. Trying to find a p/n now but no luck
dingbat
The OE washers for my Evinrude 200 Ocean Pro are nylon flat washers.
The washers deform when tightened so a new wash is required every time they are removed
Rob406
Dingbat according to the above, nylon abosorbs water. I was advised not to use it
Crosbyman
Idoubt nylon absorb water.... it deforms when crushed the first time and should simply not be reused or flipped over to save a few pennies.
still applies today on modern engines
