kingsfisherman
- Joined
- Feb 22, 2006
- 111
update #2 was able to operate trim in both up and down while using the override switch.update: I tried using the override switch and the drive comes up but won't go down. I'm sure it was in the right range to go up or down prior to the testing. So for some reason I only have trim up when I use the override switch.
I installed the trim limiter so I didn't have to guess if I was in the "safe zone" when trimming the drive. Usually the promblems I've had stem from wire corrosion and bad connectionsThere is a trim limiter module in these....I believe. Not sure when they started using these or even if they still do but you may be able to remove the darn thing and just plug in the trim wire plugs together after removing the module.
Seems dumb to have these as often as these trim senders go out!
