ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 936
youd need to drain the float bowls as well, because by the time the alarm sounds it would most likely have just raw fuel in them.I still have the original OMS pump on my '98 Johnny 150HPV6. I do carry a gal of 2 cycle oil with me at all times. Should the OMS fail, I can dump the correct amount of oil (or thereabouts) to make a 50::1 fuel mix in the 63Gal fuel tank. I would need to spend some time rocking the boat to mix it, though. It would also be a good idea to d/c the fuel line and pump primer until you see the dye in the 2 cycle oil come thru.
