flyingscott
- Joined
- Apr 8, 2014
- 8,340
That is absolutely a diaphragm pump. Clearly shows them in the pic 5 and 2. If it gets its pulse from block pull that hose off and see if it's full of fuel. It should not be
The accelerator pump is completely different than the enrichner. Also this motor's accelerator pump is not a part of the carburetors. It's a separate diaphragm that is throttle linkage actuated and plumbed to the bottom two cylinders.No it doesnt. There are accelerator pumps on the bottom 2 carbs that can leak.
editThe accelerator pump is completely different than the enrichner. Also this motor's accelerator pump is not a part of the carburetors. It's a separate diaphragm that is throttle linkage actuated and plumbed to the bottom two cylinders.
You're the expert help hin with his motor then.The accelerator pump is completely different than the enrichner. Also this motor's accelerator pump is not a part of the carburetors. It's a separate diaphragm that is throttle linkage actuated and plumbed to the bottom two cylinders.
Is there a filter on the accelerator pump? I can’t seem to see it. Unless it’s tucked in with the carbs hidden maybeThe accelerator pump is completely different than the enrichner. Also this motor's accelerator pump is not a part of the carburetors. It's a separate diaphragm that is throttle linkage actuated and plumbed to the bottom two cylinders.
Yes. There is a small filter on the accelerator pump output. It's on fuel line going from the pump to line that connects to the #3 and #4 cylinder check valves. But there should not be an issue with that filter. Not much can go wrong and the amount of fuel going through it is minimal. I'd look elsewhere.Is there a filter on the accelerator pump? I can’t seem to see it. Unless it’s tucked in with the carbs hidden maybe
