- Joined
- Jul 23, 2011
- 53,268
The plywood transom is 100x stronger than a chunk of oak. that is why the OEMs used plywood
Is the boat and the transom pod rated for more power?
The transom is rated for 115hp. I will be putting a 80 2 stroke on itThe plywood transom is 100x stronger than a chunk of oak. that is why the OEMs used plywood
Take 4 pieces of 1/2" marine plywood and tite bond 3 glueI wanted to add to my last reply. I would have used 2" thick plywood if I could have found any. I called everywhere and marine plywood could only be had in 3/4" thick. I could glue two of those together, but I would only have 1.5" thick plywood at that point. It seemed more prudent to go with a solid 2" thick piece of oak....
I will check for cracks on the starboard toon for sure. But, the port side toon is holding air, so i'm sure it has no cracks. So if there are no cracks, is the water in the port toon just from condensation?????Check the tubes for cracks where the M brackets are welded
Well, I've been out twice more for about 5 hours each time. I'm going to check the pontoons this weekend and see if there is any water in the starboard toon.Shouldn’t be condensation I would not think. Mine has breather tubes though. Mine also has cracks that someone patched with jb, which cracked also, I’m having them welded though. Every fall when I pull the toon I remove the drain plugs and it’s dry.
