Swedefj40
- Joined
- Jun 9, 2018
- 220
1996 4.3 LX, A1G2 Weber 4bbl Carb (800 hrs)... so the wife and I were at the launch yesterday, ready to head out fishing and started the motor. It ran for maybe a minute then slowly dropped rpm sputtered and died. I left it for maybe 20 seconds then tried it again and same thing. Idled for a minute then died. Third time I tried it and it stayed running for a good 5 minutes so I decided to continue on our trip.
I recently had the fuel line apart at the tank to put In a tee so that I could run my kicker off of the main tank instead of the portable 3 gal tank (added antisyphon valves to each line) so in the back of my mind I'm thinking it was just an air lock problem. Anyway, we left the dock and headed out and it ran great for the 45 minute run to where we were going to fish.
We fished (using the kicker) for about an hour and decided to run to a different spot and the same issue happened. I tried to start it 4 or 5 times and it never would stay running. I changed the fuel/Water filter no change. Swapped in a new electric fuel pump, no change.
I have voltage at the pump when trying to start.
I direct wired the fuel pump to the battery to bypass the safeties (oil pressure, water temp) expecting the pump to prime the carb and shut off but it kept running and that's when I noticed fuel dripping from a venturi into the primary bore.
Sorry for the long post but I just wanted to give as much detail as possible.
I'm going to rebuild the carb next thinking it might be a stuck float but any opinions on my issue would be helpful.
Attach files
Attach files
