- Joined
- Jul 18, 2011
- 19,383
I've been doing a bit of checking on my tri-axle trailer the past few days, as I'll probably be using it to pull the boat out of the water in the next few weeks.
I've felt that the surge brakes were not really working in previous uses of the trailer. Yesterday, I hit the calipers with a little bit of PB Blaster and took the trailer on on the (private) road that leads to the house. I did a few quick stops just to exercise the master cylinder, then did the typical test of trying to push the trailer up a slight grade with the disc lock-out disconnected. The brakes work . . . I had the truck burning some rubber just to try to get the rig to move backwards.
Today I thought to grease the hubs, since they have not been greased since the trailer was new amost 2 years ago. (not many miles though . . . maybe 100 ). Well, of the 6 wheels, I found 4 of them had grease fittings, the other 2 did not. Upon closer inspection, the hub/axle had the tapped hole for the fitting, just no fitting (not good !?!?)
4 of the 6 wheels . . .
2 of the wheels. . .
A quick trip to town to get some grease zerks and all set.
I'm glad that I checked, else bearing failure might have been right around the corner. As it is, I'll have to keep an eye on them.
These are 5,600 lb rated torsion axles (3 of them) . . . so each wheel would be handling 2,800 lbs.
