Dukedog
- Joined
- Oct 6, 2009
- 3,547
QBhoy... tha orginal poster's motor is a '84 2.0 150 motor with '89 electrics like said....
your motor looks ta be at least a 2.0 135/150 ta at most a 2.4 175.. if heads are correct with year then at least '87.. it will have a build date in tha same place as described above... carb number (WH ?) will be able ta tell horsepower probably....
tha ratio could be different on it.. all 2.0 motors came (normally) came with 2 ta 1 gears.. everything else had 1.87 ta 1's.... only exception was tha XR4 and 6.. they had a smaller "barrel" and 1.78 ta 1 gears... could be tha difference ya seein'.. with tha age of these motors nowdays its not outta tha ordinary for tha gearcases ta have been changed somewhere down tha line.. they all will fit/interchange with all of 'em from '76 up including tha 2.5 motors....
