flashback
- Joined
- Jun 28, 2002
- 4,367
Not unusual that the two sides are different temps especially if boat sits un evenThis is the line that feeds the starboard side. This side gets noticeably hotter than the port side, but I can still keep my hand on it while running. Port side is cool to the touch.
Looks like you got your money out of that one!Here's what one of mine looked like after about 25 years in what I think was fresh water tho who knows with a used boat. The other side was even worse...(a replacement on the right)
It's doesn't really, and today was on trailerNot unusual that the two sides are different temps especially if boat sits un even
That’s the point on the trailer usually side to side it will be unevenIt's doesn't really, and today was on trailer
I got the boat a couple of years ago and spent most of last summer replacing old parts. This summer I've been able to use the boat some but I find there's always something needs fixing..Looks like you got your money out of that one!
I'm with you, if I have to repower again I'll definitely go closed cooling. That and dry joint and I'd only have to replace the elbows once in a whileI’ve been on the hull truth website a long time & it is a fishing/Fla/Gulf Coast group and are very much pro out board. What I see is that you can buy a new OB but don’t expect more than 10-15 years out of it. The blocks are cast alu with coated or sleeved cyls. Open deck with free standing cyls.
More prone to overheat damage and the alu can deteriorate and undermine the sealing surfaces. I’ll take a closed cooled Chevy over a 25-30k alu wonder in salt water.
Agreed in fact when I do repower I am going to see if I can adapt the Merc Dry joint to my OMC/Volvo Y pipe. Might work because both used elbows with a 7* down slope angle.I'm with you, if I have to repower again I'll definitely go closed cooling. That and dry joint and I'd only have to replace the elbows once in a while
Outboards are nice, but they definitely have a more limited life.
