First post for me on this forum-total newbie to boats and outboard motors.
I got this 1960 glasspar boat with 1970 evinrude 115 for free… was hoping to get it on the lake before the summer is over.
Previous owner did some work on the motor - theres new hardware on one cylinder head and new gasket. But still old pistons in it. I assume just a gasket replacement?
Brand new spark plugs-never fired-suspicious,
Sprayed some lube in the cylinders, hooked up muffler, did compression test. They are all around 95-105.
Checked for spark, couldn’t get any.
Measured rectifier, was bad-replaced
Stator resistance ok-i know it doesnt need it to start.
Optical sensor in distributor measure 5.4 ohms, gapped at .028-ok
Shift diode tested - ok
Reverse spring on crank is free not shortening out - ok
Input voltage for pack 9.6V-ok
Output voltage with DVA -0 V
It does have the ignition safety switch eliminated.
I assumed is the pack - or some stop/kill circuit i dont see on the wiring diagram.
The starter is turning the engine over just fine.. just no spark.
Decided to go with the cdi electronics pulse pack what comes with new coil.
Hooked it up, tried to crank, but just a short “sparky” sound from the solenoid. After that just silence… no cranking , no sound, nothing. Lost 12V on the + starter terminal !!?? After waiting a while i can repeat this sparky sound.
With the power pack unplugged i can crank the engine and it turns over.
With the starter unplugged on output side of solenoid i get the solenoid to engage repeatedly. But as soon as i connect starter and pulse pack together, just a sparky sound and loose of voltage.
Im thinking of running new battery cables? Maybe the ampdraw with new power pack and starter is too much? Cable worn somewhere? I assume this older starter ( looks original ) draws more amp than a new one? I just dont understand how i can loose voltage , the cables are running straight to the battery. ( battery stays at 12.7 - 12.9 V )
Battery is a new class 24 marine deep cycle.
Is there any other fuse beside the inline 12V?
Any help/ideas appreciated.
