As far as which bearings. 90% are 2-bolt bearings. Run the block casting number and you will find it listed for both
The block casting number will also tell you if your block is a 1980-1984, 1985, or 1986-1987.
1985 and later is 1-piece RMS with perimeter bolt valve cover, 1986-1987 is center bolt
