04fxdwgi25
- Joined
- Mar 25, 2022
- 603
The main indicator here is the 12VDC to the coil +. That needs to be a constant.
If it comes and goes, there is a problem in the wiring harness before the coil.
Things to check, just name a few of the common offenders:
* Wiring / connections
* Ignition switch
* Man overboard / safety shut off switch
* Circuit breaker feeding everything
* On Alpha drives, the interrupt switch on the engine that shift cable connects to.
Doing a full tuneup is certainly a positive ie: plugs, cap, rotor and reluctor wheel. But throwing good money down the rabbit hole to just replace parts to see if it "fixes it" (known as Easter egging) is never a good idea.
* Ignition switch
