craig newton
- Joined
- Jul 23, 2019
- 66
84 Mercruiser 5.7l sterndrive, 4bbl, open cooling system.
Last time out it back fired a couple times starting it and seemed normal running just above idle through the no wake zone. Once through I accelerated but didn't have enough power to plane out. Wouldn't go above 15mph. The oil dipstick showed signs of water mixed in. Removed the oil filler cap and it had white sludge all over it. Also noticed a small amount of water pooling up on the intake manifold between the distributor shaft and the valve cover gasket. I was thinking a blown head gasket and started a compression check with the #7 cylinder and it read 0 compression. Could a bad head gasket alone account for no compression
