Scott06
- Joined
- Apr 20, 2014
- 7,367
Follow the service bulletin he posted I circled where you are at in it - by striking the white and green lead to ground you are simulating what the sensor in the distributor does to get the coil to fire. If it does fire at coil the sensor is bad if it does not fire follow to testing for bad coil and then bad module.Now I am getting 12v at coil +, and 11.84 coming out of module via red/wht wire, followed by 8.62 at the red/wht going into the distributor...now where do I go? Still no spark coming out of coil tower?
You just need to follow the troubleshooting guide.
