kcassells
- Joined
- Oct 16, 2012
- 8,739
I started working on this motor this summer. Hasn't been wet for about 5 years. Running high on idle @2500 rpm on hose. Chased out some air leaks etc. Pulled carbs, hoses, gaskets to manifold.
The primer fittings below had no threads at all and were tapered as if "push in." The ports were not threaded either. Carbs with fittings pic and fittings out of carb.
Here are some pics, let me know if you seen this before.
Thanks.
Assembly
Running
View attachment nicey .MOV
View attachment Engine Freakin doing its job 5 16 23.MOV
Thanks.
Assembly
Running
