Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
THis thing is driving me crazy, It runs super at low and mid speeds down the lake and at high full throttle it dies dead. then will restart and go again. Fresh plugs and good gas any idea's?
Re: 1972 evinrude 65 Dies at high speed Runs great low and mid
Tony homer I had the exact same problem on a 1986 70HP johnson.. Turns out the pick up tube inside the fuel tank was pulling in air at the top where the pick up tube is pushed on the fitting... Pull that out & check it..... E-Z FIX!!!!CHEAP TOO!!<br />Try that first..
Thanks Guys were gonna replace gas tank and gas line this weekend and try that then on to fuel pump kit next. where would I get one for this old motor?
