- Joined
- Jul 18, 2011
- 19,375
OK, I know that the color of RV/Marine antifreeze is insignificant and more arbitrary.
However, I've had a fairly strange occurrence in my winterizing last year and now this year. It seems that on the hot water side of my boat's plumbing system the AF goes in pink (or red for the -100˚F) and comes out of the hot water faucet almost clear. The cold side comes out pink (or red). Initially, I was thinking that I needed to run more AF to purge the water heater, and actually . . . I did drain the existing water from both the supply tank and the water heater tank.
After pumping nearly 20 gallons of AF through the hot side and seeing little/no color (i.e. clear liquid) I came to the conclusion that something in the hot water side might be reacting with the dye in the AF and making it clear. Copper maybe? The stuff coming out of the faucet has definitely got the alcohol smell to it.
2 years ago I noticed a similar lack of color when I drained down the heat exchanger of the engines. I thought it was water, but I smelled the alcohol. . . so it lost its color.
So, does certain types of plumbing react with the dye in AF? copper maybe?
