MaxGlide
Thread starter- Joined
- Aug 20, 2020
- 194
1977 Mercruiser 140, four cylinder engine, serial #3847982. Using a mechanical fuel pump.
Ran boat completely out of gas (faulty gas gauge showing more than we had).
Put gas back in, new fuel filter, filled up fuel filter with gas.
Fuel line from tank to filter unit is clean and clear.
Not self priming, or priming using bulb going to small motor. (Used to be able to pump until bulb got hard)
Won’t start while turning over.
Few tablespoons in carb, fires right up and runs until fuel level drops below intake spout in fuel separator unit.
When you take the filter off, it is always down about 1”.
All connections checked.
Fuel filter on top of fuel pump is collapsed as in photo. Could this be the problem?
Could I bypass fuel filter and connect hose from tank directly to fuel pump to see if something around the fuel filter assembly is the problem? (Of course not run it like that permanently)
Could the fuel pump have failed when we ran out of gas?
Any insight is very much appreciated!
