Capt dave 258
- Joined
- Jul 14, 2021
- 71
Recently picked up a very clean 1982 Mercury, 50 hp. Compression test is about 150 in all 4 cylinders. Put it in the lake today for the 1st time and it had intermittent power, never getting on plane. Brought it home and ran it with muffs. Removed coil wires one at a time and noticed no difference with #2 coil wire removed; couldn't hear a spark when removing the wire and no difference in rpm's. Tested all 4 coils and they all fell within the acceptable range. Switched plugs around from cyl 1 and 2 and still no spark in cyl 2. Checked resistance on #2 coil wire and it was fine. Checked the wires from the cdi for cyl 2 and resistance was fine on those. I'm thinking it's the cdi and don't mind spending the money if that's the problem. Is there someway I can test the cdi to determine if that's the issue? Is there something else I should be looking at? Any help is appreciated.
