Need a Stator for 1994 Force 70 Outboard
jbiasotti
First post, but thank you ahead of time for everyone's knowledge!! I have read and learned a lot over the years on repairing motors! This is my first motor repair with bad electronics. I read through other posts and pretty sure I have a bad stator. Picked up a very cheap boat for the motor that has good compression- 120 psi all 3 cylinders. Cleaned carb, hooked up and no spark all 3 plugs. Researched site. 1st eliminated ground or emergency shut off- unplugged black and white wire to CDI - tested no spark. Unplugged both yellow wires from Stator to rectifier- tested no spark. Unplugged both blue and red leads from stator and ohmed out. The red (low voltage?) was 115 ohms and the blue wire (high voltage) was open- no reading- tried many different ground points and open- no continuity. I assume stator is bad? I looked up on Popular Marine shop and get part #398-8778A29, but no stock. Looking at collective threads it looks like a 9 amp system. Here is my problem. The cross- reference unit from CDI electronics 174-8778k1 has 6 wires- 2 red, 2 blue and 2 yellow. My original has 1 red, 1 blue, 2 yellow and a black ground. Can I use this part? and how do I wire it up? Hopefully this will fix it and the CDI and rectifier are still good- didn't want to spend a lot of money. I will have to look further into threads to see how to check if CDI or rectifier is bad. I figured my only option is to replace first what is bad and then move on? I was thinking of testing the electrically output from the stator to further verify it is bad, but I need some type of shunt or device for my regular volt meter to read that 800 volts I believe?
The Force power
I did a quick search (tried to copy & paste, but did not work. however the product you found is the correct one and it has the explanation of the hook-up
kalebsheridan
I ran into a similar problem with my motor recently. I had a dead stator and trigger. I ordered a stock trigger and a CDI stator off eBay. I consulted a couple suppliers to make sure I got the right CDI stator. It too had more wires than my stock stator. I think it's designed to fit multiple models of force motor. The wires were similar colors, and the leads to the ignition coils were different colors, but were numbered. Hooking up the correct number lead to the same number coil worked.
kalebsheridan
Be careful with buying used electronics off Fleabay
Yeah I had to be very careful. Only reason I used eBay was because a new stator or from a reputable source would have been at least $300 for CDI and $600 for OEM. I like my motor but I'm not throwing that kind of money at it. I was especially sure that there was a warranty on the parts I bought.
