frostystorm
Thread starter- Joined
- May 22, 2023
- 21
I was winterizing my boat and the first thing on my check list was to replace the fuel filter since it's never ever been done (it needed it).
I guess on the muffs there wasn't enough water coming in, misaligned muffs, or something else, that I wasn't getting enough water to the impeller while attempting to crank an engine with no fuel it just wasn't getting enough water into the lower unit and toasted the impeller. So I am in for that job... sigh
But I didn't notice this until the engine hit 200 degrees and there was quite a bit of steam coming from the idle relief ports. I would say it ran at 200 for probably 30 seconds as I went to the garage to get a bunch of stuff I needed.
I shut it down, finished winterizing (pumped oil, new oil and filter, checked the lower unit for water in the gear lube), and I did compression across all 4 once it cooled down, 145 PSI across all 4, cylinder 2 was 120 the first time I checked it but I re-checked it because it's under the shift linkage so I just think I wasn't tight enough.
Besides compression which is fine, anything else I should keep an eye on? Anything I should look for while I have the lower unit off this winter for a new impeller?
